Fuji X70 - erste Spezifikationen
dirk
CI Gründer
Admin
15 Mai 2002
Hier von der offiziellen Fuji Webseite (Stand 14.1.2016)
Specifications
Number of effective pixels 16.3 million pixels
Image sensor 23.6mm x 15.6mm (APS-C) X-Trans CMOS II with primary color filter
Total number of pixels: 16.7 million pixels
Storage media SD memory card / SDHC memory card / SDXC (UHS-I) memory card
File format
Still image
JPEG (Exif Ver 2.3)*2, RAW (RAF format), RAW+JPEG (Design rule for Camera File system compliant / DPOF-compatible)
Movie
Movie File Format: MOV
Movie Video Compression: H.264
Audio: Linear PCM Stereo
Number of recorded pixels
L: (3:2) 4896 x 3264 / (16:9) 4896 x 2760 / (1:1) 3264 x 3264
M: (3:2) 3456 x 2304 / (16:9) 3456 x 1944 / (1:1) 2304 x 2304
S: (3:2) 2496 x 1664 / (16:9) 2496 x 1408 / (1:1) 1664 x 1664
<Motion Panorama>
180°: Vertical: 2160 x 9600 / Horizontal: 9600 x 1440
120°: Vertical: 2160 x 6400 / Horizontal: 6400 x 1440
Lens
name
FUJINON single focal length lens
focal length
f=18.5mm(35mm format equivalent : 28mm)
full-aperture
F2.8
constitution
5 groups 7 lenses (2 aspherical glass molded lens included)
Aperture F2.8 - F16 1/3EV step (controlled with 9-blade aperture diaphragm)
Focus distance Approx. 10cm - Infinity / 3.9in. - Infinity
Sensitivity AUTO (Control available up to ISO 6400)
Equivalent to ISO 200 - 6400 (Standard Output Sensitivity)
Extended output sensitivity : Equivalent ISO 100, 12800, 25600 and 51200
Exposure control TTL 256-zone metering, Multi / Spot / Average
Exposure mode Programmed AE / Shutter Speed priority AE / Aperture priority AE / Manual exposure
Exposure compensation 3.0EV - +3.0EV, 1/3EV step
(movie recording : -2.0EV - +2.0EV)
Face Detection Yes
Shutter speed (Electronic Shutter mode) 1sec. to 1/32000sec. *3
(P mode) 4sec. to 1/4000sec.,
(All other modes) 30sec. to 1/4000sec.,
Time 30sec. to 1/4000sec.,
Bulb (max.60min.)
Continuous shooting Approx. 8.0 fps (JPEG : max. approx. 10 frames)
Approx. 3.0 fps (JPEG : up to the capacity of the card)
  • * Recordable frame number may vary depending on the type of memory card used.
  • * The frame rate varies with shooting condition and the number of images recorded.
Auto bracketing AE Bracketing (±1/3EV, ±2/3EV, ±1EV)
Film Simulation Bracketing (Any 3 types of film simulation selectable)
Dynamic Range Bracketing (100% · 200% · 400%)
ISO sensitivity Bracketing (±1/3EV, ±2/3EV, ±1EV)
White Balance Bracketing (±1, ±2, ±3)
Focus
mode
Single AF / Continuous AF / MF
type
Intelligent Hybrid AF (TTL contrast AF / TTL phase detection AF), AF assist illuminator available
AF frame selection
Single Point AF : 49 areas on a 7x7 grid (Changeable size of AF frame among 5 types), Zone AF : Selectable with 3x3 / 5x3 / 5x5 areas from 77 areas on an 11x7 grid, Wide/Tracking AF : Automatic selection from 77 areas on an 11x7 grid
White balance Automatic scene recognition
Custom / Color temperature selection (K)
Preset : Fine / Shade / Fluorescent light (Daylight) / Fluorescent light (Warm White) / Fluorescent light (Cool White) / Incandescent light / Underwater
Self-timer 10 sec. / 2 sec. Delay
Interval timer shooting Yes (Setting : Interval, Number of shots, Starting time)
Flash Auto flash (Super Intelligent Flash)
Effective range:(ISO 1600) approx. 30cm - 7.9m/1.0ft. - 25.9ft.
Guide Number: approx. 5.5(ISO100·m)
Flash modes
Red-eye removal OFF
Auto / Forced Flash / Slow Synchro / Suppressed Flash / Commander
Red-eye removal ON
Red-eye Reduction Auto / Red-eye Reduction & Forced Flash / Red-eye Reduction & Slow Synchro / Suppressed Flash / Commander
  • * Red-eye removal is active when Face Detection is set to ON.
Hot shoe Yes (Dedicated TTL Flash compatible)
LCD monitor 3.0-inch, aspect ratio 3:2, approx. 1,040K-dot Tilt-type, TFT color LCD monitor (approx. 100% coverage)
Movie recording Full HD 1920 x 1080 60p / 50p / 30p / 25p / 24p, Continuous recording : up to approx. 14 min.
HD 1280 x 720 60p / 50p / 30p / 25p / 24p, Continuous recording : up to approx. 27 min.
  • * Use a card with SD Speed Class with Class 10 or higher
Photography functions Advanced SR AUTO, Eye detection AF, Face Detection, Interval timer shooting, Auto Red-eye Removal, Select custom setting, Motion panorama, Color space, Setting (Color, Sharpness, D-range, Gradation), Film Simulation, Advanced Filter, Framing guideline, Frame No. memory, Histogram display, Preview depth of focus, Lens Modulatioon Optimizer, Pre-AF, Control ring setting, Focus check, Focus Peak Highlight, Digital Split Image™ *4, Electronic level, Multiple exposure, Release priority / Focus priority selection, Fn button setting (RAW, Movie, etc.), ISO AUTO control, Instant AF setting (AF-S/AF-C), Interlock spot AE & Focus area, Focus area setting, AE-L/AF-L button setting, Edit/Save quick menu, Preview exp./WB in manual mode, Shutter Type, Touch screen setting
Touch screen mode
Shooting Mode : Touch shooting,Focus area, OFF
Display Mode : Swipe, Zoom, Pinch-in / Pinch-Out, Double-tap, Drag
Film Simulation mode 11 type (PROVIA/STANDARD, Velvia/VIVID, ASTIA/SOFT, CLASSIC CHROME, PRO Neg Hi, PRO Neg. Std, MONOCHROME, MONOCHROME+Ye FILTER, MONOCHROME+R FILTER, MONOCHROME+G FILTER, SEPIA)
Dynamic range setting AUTO, 100%, 200%, 400%
Advanced filter Toy camera / Miniature / Pop color / High-key / Low-key / Dynamic tone / Soft focus / Partial color (Red / Orange / Yellow / Green / Blue / Purple)
Playback functions RAW conversion, Image rotate, Auto image rotate, Face Detection, Red-eye reduction, Photobook assist, Erase selected frames, Image search, Multi-frame playback (with micro thumbnail), Slide show, Protect, Crop, Resize, Panorama, Favorites
Wireless transmitter
Standard
IEEE 802.11b / g / n (standard wireless protocol)
Access mode
Infrastructure
Wireless function Geotagging, Wireless communication (Image transfer), View & Obtain Images, Remote camera shooting, PC Autosave, instax printer print
Other functions PictBridge, Exif Print, 35 Languages, Date/Time, Time difference, Sound & Flash OFF, High Performance, Preview exp. in Manual mode, LCD Brightness, LCD Color, Preview Pic. Effect, DISP. Custom Setting
Terminal
Video output
Digital interface
USB 2.0 High-Speed / micro USB terminal
  • * connectable with Remote Release RR-90 (sold separately)
HDMI output
HDMI Micro connector (Type D)
Power supply NP-95 Li-ion battery (included)
Dimensions 112.5mm (W) x 64.4mm (H) x 44.4mm (D) / 4.43in. (W) x 2.54in. (H) x 1.75in. (D)
(Minimum Depth : 25.9mm / 1.02in.)
Weight Approx. 340g / 12.0 oz. (including battery and memory card)
Approx. 302g / 10.6 oz. (excluding accessories, battery and memory card)
Operating Temperature 0°C - 40°C (+32°F - +104°F)
Operating Humidity 10 - 80% (no condensation)
Battery life for still*5 images Approx. 330 frames
Battery life for movies Consecutive movie recording : approx. 86 min. (Face detection is set to OFF)
  • * Individual movies cannot exceed approx. 14 min. on Full HD mode, and approx. 27 min. on HD mode in length.
Starting up period Approx. 0.5 sec., when High Performance mode set to ON
Approx. 1.0 sec., when High Performance mode set to OFF
  • * Fujifilm research
Accessories included Li-ion battery NP-95
AC power adapter AC-5VF
Plug Adapter
Shoulder strap
Lens cap
Metal strap clip
Protective cover
Clip attaching tool
USB cable
Owner's manual
Memory Card Capacity and Image Quality / Size
ll figures are approximate; file size varies with the scene recorded, producing wide variations in the number of files that can be stored.
Number of images
Modes Still image (L)
4896 x 3264 (3:2)
Quality
JPEG FINE JPEG NORMAL
SDHC memory card
8 GB 809 1210
16 GB 1668 2494
Number of images
Modes Still image (M)
3456 x 2304 (3:2)
Quality
SDHC memory card
8 GB 1608 2396
16 GB 3315 4940
Number of images
Modes Still image (S)
2496 x 1664 (3:2)
Quality
SDHC memory card
8 GB 3304 4439
16 GB 6253 9149
Number of images
Modes RAW
SDHC memory card
8 GB 232
16 GB 480
Recording time
Modes Movie
Quality
FULL HD (1920 x 1080) 60p HD (1280 x 720) 60p
SDHC memory card
8 GB 26 min. 51 min.
16 GB 54 min. 105 min.
  • * For recording movies, use a card with SD Speed Class with Class10 or higher.
Hallo Dirk.
Nicht wirklich. Es gibt bei Youtube schon etliche Vergleiche zwischen der GR und der X70, einfach mal suchen. Die Gehäusegrössen sind nahezu identisch, mit dem einzigen Unterschied, dass die GR das Objektiv bei Nichtgebrauch einzieht.
Wenn Du nach "Bigheadtaco" suchst, findest Du ein paar ganz brauchbare Videos.
Matthias
was mich momentan an der X70 ggü. der Ricoh GR stören könnte:
- sie hat keinen eingebauten ND Filter (GR hat das)
- man kann sie nicht mit einer Hand halten und gleichzeitig mit der gleichen Hand bedienen
- den Hauch dicker, sodaß sie nicht mehr in die Hosentasche passt
- Batterien wie X100X100s/X100T und nicht wie X-Pro1/X-T1
- schlechtere s/w Bilder ooc
was mich an der X70 reizen könnte ggü. der GR:
- Klappdisplay und Touchscreen
- vermutlich bessere Jpeg Engine
- Crop Modus 35mm und 50mm mit Hochrechnung auf 16MP (bei der GR wird die MP Zahl kleiner). Besserre BQ (?)
- Wifi
- Längere Batteriedauer (?)
- WCL-X70 Wieitinkel (21mm) Adapterlinse leichter aufzusetzen als bei der GR
- ISO-Auto minimum Verschlussziet eventuell auch bei 1/500s (?)
- Display bei grellem Sonnenlicht besser nutzbar (?)
- Objektiv noch besser als von der GR (?)
- High ISO besser
- AF schneller (?)
- Wie gut ist die 21mm Adapterlinse?
VG
